Elkins45
Site Donor 2026
I bought a 2012 with bad paint back in the summer (https://bobistheoilguy.com/forums/threads/scion-rustoleum-roller-job-is-finished.389467/) and because I painted it in sections it’s not been driven much until now after the paint is done. In fact, I realized that this morning when I took my wife to the airport well before dawn was the first time I had driven it in the dark. This was obvious to me as soon as I pulled but of the driveway because once we were on the open highway it was almost too dark to see unless I left the high beams on all the time. It was scary.
I pulled over and determined that the low beam bulbs were both lit, just extremely dim. The brights were perfectly normal. I bought and installed a new set of bulbs as soon as the Walmart opened at 6am and they made a slight difference, but the car was still scary without the high beams.
I had used a headlight restoration kit on the outside and the outer lenses look clear, but obviously there’s something going wrong inside the little “tunnel“ where the low beam bulbs mount. Has anyone ever experienced this? Is the best solution just to pony up $200 for new headlight clusters? Or maybe spend $30 and shove some cheap Chinese LED bulbs in it first to see if more light is enough to blast through?
The problem isn't that they are aimed too low because the high beams are exactly the same as in my 09.
