The shaft is solid steel. Do you have an example off this happening?The oil causes drag in the turbo bearings, more viscous = more drag and more twisting of the shaft. You could snap the shaft in half asking full boost on a cold engine.
Who said it is just about turbo damage? Just a good rule to not use a motor hard until it is up to operating temp. Some of us make a little more power than a base Accent.View attachment 78194
I'll just stick this here to remind everyone we're on an scientifically based oil forum.
Please show me the rational for risking damage to your turbo due to oil starvation that makes some of you wait until you see 100 C oil temps.
Does the viscosity difference at 80 C make you nervous?
60 C?
If turbos were as delicate as this message forum seems to suggest I'd wager we'd be seeing lots more failed turbos, yet it's considered pretty rare outside of super high mileage.
I've literally screamed at co-workers who fired up our Bobcat Toolcat turbo diesel and John Deere turbo diesel tractor on a cold start and went straight to full throttle. Like, what the heck dude.
And that makes me a lot of money! Especially when I worked at Acura and got to replace a LOT of carboned up pistons. Thank you oblivious soccer moms.50,000,000 soccer Moms have already proven that engines and turbos won't explode when the piss is beaten out them stone cold.
They do it with dirty oil too........
60 C?
It isn't the oil alone what matters. Both oil temp and coolant temp are
indicators for the engine hardware. After start-up the piston temp raises
very quickly, while the cylinder sleeves as well als the entire crankcase
only slowly raise in temperature. As a consequence the piston expand
while the cylinder sleeves haven't yet. Perhaps that's the main reason for
increased wear during warm-up. It takes time distributing, say spreading
the heat. So the oil temp itself isn't the only thing to look for. The other
contributing factor is time. While it's easier to say your engine is ready
to rev at say 80°C/175°F it's probably not a bad idea to wait at least ten
minutes also.
That said, overcautiously lugging an engine results in slowly getting up
to temp and as a result the engine may not get up to full operating temp
at all on shorter distance trips, causing oil dilution as fuel and water aren't
allowed to evaporate.
Come on now, we are talking about OIL TEMP. Once oil temp is up in the ranges I referenced in my post we are already talking about Coolant, thus cylinder walls that have reached normal operating temperatures.Again, oil viscosity is a lesser issue. It's the piston and cylinder sleeve
pairing actually. You don't want the pistons fully expanded while the
cylinder sleeve is still tight, inevitably leading to increased wear. Did
you read my post?
Now you're thinking with your dipstick.So this is supposed to be a ****-measuring contest? Nice prospects!
I think you are typical of most drivers. No one gives much thought about their car engine.In my area of CA where it never gets below 32F....the matter is irrelevant. Full throttle as soon as it leaves my driveway, if-needed.
Because they already last long enough for the average consumer...I think you are typical of most drivers. No one gives much thought about their car engine.
Possibly take a look at the original post. The question asked about OIL TEMP in a Turbo engine. My point with my post was to illustrate the FACT there is only 20 cST difference in viscosity in a 5W30 motor oil with a temp range from 60C to 100C which in my opinion is not enough to make one bit of difference from the turbo's perspective, especially considering today's automotive turbos which are not only oil cooled/lubricated but water cooled, which if you paid attention was the original premise of this thread.
