OK guys, take it easy on a noob here. (I did search but couldn't find what I was looking for...)
I want to know what is the best/easiest way to draw an oil sample for a used oil analysis.
I mean...how do you guys physically draw a sample from the motor, if you intend to run a used oil analysis WITHOUT a full oil drain?
Do you....
1. try to drain some from the oil drain plug (unscrewing the plug, dropping some oil and trying to very quickly stem the flood of oil? Must be REAL messy?)
2. Use an oil extractor> If so...which type works well?
3. Other?
I have an Audi S4 with the V8 motor.
Thanks all!
Do you....
3. Other?
Thanks all!
