As many years of experience as I have I have only installed one filter on a Motor Cycle and it was my own. It was a Honda 500 custom with the V twin. It had the canister oil filter with the little make believe cartridge. I pulled off the canister and presto I had a sealing surface the same as a Chevy V8. I dug around in the shop and found a full flow filter nipple that screwed into the engine in place of the center bolt. There it was only a matter of installing a sandwich adapter that fit. I was selling the Frantz at the time and hung it upside down back by the saddle bags. The Perma-Cool adapter works better than the old Frantz two port adapters because of the spring relief valve. Small engines sometimes don't have enough oil flow to heat up the Frantz or Motor Guard. With the Perma-Cool adapter it doesn't matter. The spring holds a slight pressure on the bypass filter. Most of the little engines with full flow filters like the 20 HP Kohlers take a Ford full flow filters. I hooked up the little generator in the conventional way because the adapter added too much length to the filter. I didn't want to cut the frame.quote:
Originally posted by oldman:
RalphPWood would be the one who probally has. He has pictures on his web page using a bypass filter on small engines.
Does it share a filter with a larger engine? Is there a non-proprietory/OEM filter available for it? If so ...type it into the Wix or Baldwin filter X-reference applets and see what the thread and gasket diameter is. Then you can see if an adapter is available for it.quote:
It is a 1992 300 Fourtrax w/the small oil filter on the side of the engine.
Here is a pic of the filter:quote:
Either way, Ralph should be able to hook you up if you like the economy and fine filtration of TP.
Amsoil also has a cheaper bypass mount that has a .030 restrictor on it. That can be tapped to your sender and not tax any flow. You only need to figure out how to return it to the pan. I would think that you could buy an extra oil plug and drill and tap it to attach your fittings.
