How to increase font size in "code" command
Rancho Cucamonga, CA
When posting UOA results using the Code command for proper formatting, is there a way to make the font size larger? I found on my last UOA post the result code was so small it was difficult to read.
Thanks.
Thanks, I'll try that. What I've been doing is just typing the numbers straight into the message box on this message board. So, between the two "code" commands (UBB Code) I just type the data straight in and in the message box the text/font looks identical to everything else that's not between the "code" commands, but when the message is posted, the font shrinks really tiny for the text that the "code" command applies to, while the text outside the "code" command remains normal size.
I would like to know this too. Cutting and pasting into the code tags with a larger font doesn't help. I tried using the "size" tags without success also.
The font for the code tags is really tough to read. Moderators?
