How to gap twin tip plugs?
Australia
Hi guys,
So I ordered and received a set of BKR7EKC-N spark plugs.
I wanted to gap them to the right measurement (1.1mm) but when I opened the box these had twin tips on them like this:
https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQAf0M_EXMMK6AUTBlEJ_cZBMaQmLGCfuDgtzmm6U9Cdu8vVN7U
How do I gap these?
I guess like any other plug. Measure, then lift or depress the tip for both. Electricity should follow one or the other path, which ever is easiest.
NGK doesn't recommend it but you can if you must for some reason e.g.dropped it with a wire gauge on both sides.
Originally Posted By: NGK
Gapping is not recommended on Multi-Ground plugs.
Originally Posted By: Lolvoguy
You dont' gap them, that's how.
The more I read, the more I'm changing my vote to this.
If it were a precious metal plug with thin electrode you absolutely do not want to mess with them, yours are standard electrode and not as fragile but like I said only if you must not as routine plug inspection before installation.
