How to enter Diagnostic Mode on GE Front Load Washer
Toronto, Canada
Model GCVH6400J1WW. I contacted GE Canada but they would not give me the procedure. Tried some Internet suggestions but did not work
1) Hold Start button for 10 secs
2) Signal-Delay-Signal-Delay
3) Siganl-Extra Rinse-Signal-Extra Rinse
4) Hold Start
button and turn selector knob CCW And then CW
One of the above is probably the correct one and I am not doing it right.
Try this procedure:
To enter diagnostic mode on a GE GCVH6400J1WW washer and check for error codes, follow these steps:
  1. Ensure the washer has been recently plugged in: If it hasn't, unplug it for 30 seconds, then plug it back in and wait 15-30 seconds for the system to boot up.
  2. Press and hold the Start button.
  3. While holding the Start button, rotate the main dial counterclockwise seven times.
  4. Release the Start button. The washer should chime, indicating it has entered the diagnostic system.
  5. To view error codes, rotate the knob clockwise.
  6. Pressing the Start button will cycle through any stored error codes.
To exit diagnostic mode, press the power button.
Note: This diagnostic mode allows you to check for error codes and test various components of the washer. You can use online resources or a service manual to interpret the meaning of specific error codes. Remember to disconnect power before servicing your appliance.
It is similar (but counterclockwise) to the top loader diagnostic procedure shown in this video around the 1 min, 40 sec. mark.
