Originally Posted By: peterdaniel
besides, if you unscrew the filter, you will destroy the gasket and it will not seal properly anymore.
Did you actually have evidence that the gasket was destroyed after the filter was removed ?
Originally Posted By: paulo57509
I could me mistaken, but wouldn't all the oil drain out of the flter if you just remove it and turn it upside down?
ADBV keeps oil in the filter, that is its job.
The reason for re-using oil filter is Honda recommends filter change on second oil change. Leave filter untouched would leave up to 1/2 quarts old oil in filter and filter mount. By removed filter and drain all old oil out, without damaging the gasket, would remove most used oil from engine.
On my last oil change, by removed filter I would be able the drain about 10-12 ounces old oil from filter mount and filter itself, after turned filter upside down for 1 hour. But the filter still has some oil in it, my guess is it still had about 6-10 ounces.
