How to convert motorcycle tire sizes?
Erie, PA
I was hesitant to post in the motorcycle section as its gear more towards lubes. I have a 90/90-18 front and a 110/90-18 rear. Would like to put dual sport tires on and cannot get these sizes. Duro has some tires that look like the tread I want, but I dont know how to convert properly.
Example the front tire is the important one for the speedometer accuracy. 90/90-18 converts to a 2.75/3.00x18. So what one do I buy? A 2.75 or a 3.00? I am just not understanding.
Are there any on-line owner's groups for your make/model of motorcycle? You surely aren't the first to run into this problem, and likely they already have the answers for you.
The 2.75 will keep your speedometer the closest to what you have now, that said I would go with the 3.00.
I've found motorcycle speedometers to be very inaccurate, usually reading higher than the actual speed.
I always up size if I can, never downsize.
agree here...nice post
What motorcycle is it? I have a bike that gets it's speed and odometer signal from the countershaft sprocket. Others which use the ABS/wheel-speed sensors, and some of the old ones I've had have the speedo/odo drive from the front hub.
Believe if you test them you will find they read 8% or so high. But the odometer is exact.
“ECE Regulation No. 39, which is a 14-page document detailing speedometer accuracy for vehicles sold in EU countries. According to this law, a speedometer can read high by as much as 10 percent plus 4 km/h at a specified test speed, but under no circumstances can the speedometer read low.”
There are 25.4 mm in an inch. So 90 mm would be 3.54 inches. The second 90 is the sidewall height as related to the width in percentage. So a 90 height would be 3.54 times 90 percent or 3.2 roughly. And the 19 is the rim diameter. Hope this helps
Don
