How Should Original ATF Look After 66k?
CA
I just serviced the automatic transmission on a 2005 Infiniti G35.
I am puzzled on whether this transmission had been serviced at the 30k service. All of the maintenance was previously done at the dealer, but I don't know if the "premium schedule" 30k service was performed.
Before the service, the fluid was the color of NEW engine oil. I drained the pan and refilled with about 3.8 quarts of Nissan Matic-S. The unit holds 11 quarts, so only 35% of the fluid was replaced.
Since the fluid was amber before I serviced the transmission (and is now light red), I think that the transmission had been serviced before. Also, the drain plug was barely tight, which I think may be a sign that the plug has been removed before. Original fluid after 66k on a hard-driven, performance sedan should have looked worse, right?
What do you guys think?
Not sure about the color thing. I checked the ATF in my Frontier (Matic S from the factory) the other day just for something to do LOL.
It was as clear as water. No dye in it at all? I asked around on the Nissan forums, and this seems to be the trend on the "newer" Nissans. I guess they want to know if you've touched the transmission? Heck, my dipstick is even bolted down.
Transmission fluid color tells only part of the story. Some types seem to have have lighter, less long lasting dyes than others. Other ATFs like Toyota Type IV/Mobil 3309 in most AW trans' turn gray relatively quickly. And Aisin transmissions are overall pretty reliable.
