Based on the oil analysis you have secene, what you've read here, and your personal experience, how often should I change the oil in my turbocharged eagle talon, using Supertech 10W30 and the ST 7317 filter?
The engine has been rebuilt, but I don't kjnow how many miles it really has. Maybe 50-60K, but I'm not really sure.
It uses a little oil, but not too bad. I only see a little smoke when I boost it hard, but no valve seal leaking oil smoke or bad rings type of smoking.
The car is driven in commuting traffic from suburbs to city, about 30 miles a day, combination of highway, and city. The traffic can be pretty bad here. I look at the traffic cams and plan my route accordingly. But it's kinda severe duty.
Right now I chnage it about every 2500 or so miles. Or 2-3 months.
The engine is a mitsubishi 4g63 2.0 DIHC turbo.
Seeing these oil analysis for ST, I see it looks like after about 4K in an NA car, it's needing changed?
Well in a turbo car, this stuff might be needing changed more frequently?
