How often should clutch fluid be replaced?
No, because that doesn't get rid of the junk in the hoses and slave cylinder. That old fluid can be even more foul than what is in the reservoir.
You can open the bleeder and just let it drain. use a hose and don't the fluid get on any painted surface. This will get fresh fluid quickly in the system.
Keep your reservoir full - don't let her run dry when doing this!
And DON'T touch the clutch pedal with this procedure.
