Originally Posted By: Familyguy
Or just remove the return line from the PS reservoir and direct that into a bucket. Start the car and in about 3-4 seconds the power steering pump will pump all of the old fluid into the bucket for you. Shut her down, replace the return line and refill. I generally do this, then drive it around for a little while, then do it again to get the most crud out that I can.
Another way to remove fluid from each side of the rack/steering actuator all at once without having to go for a drive is to *not* start the engine but simply turn the wheel lock to lock. It helps to raise the front somewhat first to unload the tires. Try it next time - much less drama and very effective.
