I am sweating bullets,,, this is my first real long interval oil change I did a used oil analysis on the Mobil 1 Extended Performance that is in my Toyota 3.4L V6 engine, it said it was ok for continued use at 5K miles. I changed the filter and topped it off. I am going to run it for 10-11K miles total and do a used oil analysis on it at the end. After I do the sample should I do a LC flush or dont worry about it? The truck will only have 37K+ miles on it at the 10K mark. I have pretty much fed it amsoil or Mobil 1 since 10K miles. Valvoline conventional for three changes before that. Can LC be bad for gaskets/seals if you do regular 10K mile flushes with it?
