Originally Posted By: ziggy
Johnny, your the best man
Well, a month ago, i ran an entire bottle of regaine wth about 7 1/2 gallons of gas. I also ran 2 cans of berryman B 12, becuae i had read about it here, and was curious and all..2 cans of berryman made the car run smooth as butter!
It made me think too, because 4 or 5 times over the years, i had run stp gas treatment with mobil gas, on about 10 gallons max. EVERY time i used stp gas treatment, no lie, my oil light would go on, and car would want to stall. Ide stop using it, and car would run fine. So, another reason why i was curious about the gumout gas treatment.
Did the light come on, and then the car ran like [censored] or did it run like [censored] causing the oil light to come on?
The low oil pressure light energizes only when the oil pressure is down to nil. The light pretty much tells you that something is very wrong, and if you don't pull over very quickly and shut down the motor you'll be looking for a new motor or a new car very soon.
However, if your car was running like [censored], and near-stalling, the oil pump would also slow down to the point that the pressure would drop to the low oil pressure light pressure.
