quote:
Originally posted by bruce381:
"A grade is a starting place that falls within a range. Nothing more. Otherwise oil blenders would be formulating at the bottom of every range. Reading comprehension has nothing to do with mathematics."
OK I'm an Oil blender we shoot for Mid range as does everyone because of the effect of shearing if I blended to the bottom range I'd be OUT OF GRADE in the shearing portion of the API approval and thus my oil would NOT be in grade. And if the oil shears out of grade it is OUT OF GRADE.
Yes there is a range say 12.5 to 16.5 for 40wt anywhere in the range you are ON grade but to pass the shear tests you are better off at the mid point. Also blends DO vary in vis and shooting for a mid range will assure ON grade oils.
Bruce
I originally wrote my quote with a qualification of synthetic long oil drain interval oils but the sentence became long and awkward. Rather than edit for two sentences I cut out the qualification changing the meaning. Sorry, next time I will leave my original meaning intact so as not to cause any confusion.
On the shearing part. yes the ranges were designed for conventional oils which use lots of VII which do cause the shearing loss of viscosity. From all the synthetic UOA I have seen on synthetic oils I don't see shearing as a problem and I see synthetic oils formulated at around 10cst Mobil 1 for 30w and I also see oils formulated at 12cst GC.
It would appear that hitting the midpoint with synthetic oils is much harder to do given these two examples.
If all the synthetic blenders put their oils in the midrange, how would I get my thick 30w with >3.6 HTHS? I would have to move up to a middle 40 weight as my only option.
Until recently with the advent of the newer euro oils being available here in the USA, the same engine would get spec'ed for a 50w in Australia, 40w or 50w in Europe, and 30w or 20w in the USA. Oil weight decisions by auto makers seem to be more geo/political than scientific.
When I read that 3mp believes that auto makers spec an oil weight for a mechanical reason I just have to smile. The exception being some of the German/European manufacturers or performance cars which receive synthetic from the factory.
Which oil would you say has more life left in it? One which starts out at 10.1cst and is now at 11.9cst after use or one which starts out at 11.9 cst and hasn't been used yet. Assume all other variables to be the same. ie. rate of oxidation,add packs,...
Would they both be in equal shape at 12.5cst and have the same amount of life left in them?
There appears to be two scools of thought here on this forum.
1. Those who condemn both at 12.5 based on the end of the range.
2. Those who condemn both based on when their condition warrents it regardless of a range.
I fall into camp #2.
How about a Poll.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=1;t=011519
