Maybe 1-2 years ago.How long ago was that? The sample report on their site shows it as one of the report items, and Oil Analyzers (same place AFAIK) has it on their reports too
Thank you for your answer.not sure if anyone is using Antimony any more due to the SQ/GF-7 and for that matter Titanium maybe a thing of the past too , as these components are getting rather pricey, and moly and boron are the more prevalent offerings from the additive companys.
No, thank you for joining discussion.Maybe 1-2 years ago.
An engineer first behavior is curiosity and questioning, that easy to find anything numeric nowadays with a little dedication.You didn't provide a link to a website, how is he supposed to have looked at it? And what company is this?
Thank you overkill, yes, you need to know some, like in many other areas...Oils are a balancing act, performance improvement in one area can negatively impact another, this is why extensive testing is done to ensure the efficacy of formulation changes and component selection. Dosing that carefully balanced chemistry with another component, be it an EP additive, FM, thickener, cleaner...etc. WILL have an impact on the performance of the product, and the odds of that impact being overwhelmingly positive are impossibly remote.
This is something I've discussed with Dave at @High Performance Lubricants quite extensively. Each additive package and base oil blend responds differently to different FM compounds and compound combinations. While a full-SAPS A40 additive package in a 0W-40 might respond best to a 60/40 blend of trimer/dimer moly and not respond well to additional augmenting with say titanium, an API SP/dexos additive package might respond best to a 10/80 blend of trimer/dimer moly and a 10% dose of titanium. Or a mid-SAPS C40 additive package in a 0W-30 might respond best to a 80/10 trimer/dimer blend with 5% tungsten and 5% antimony. I'm pulling these numbers out of my posterior, but the message here is that different suites of additives, in concert, respond differently to additional components and the base oils, PPD's, VII's and other components also influence this. That's what full formulation is all about.
Now, you are less likely to see some of these compounds used in OTS lubricants due to cost, and it's not unusual to see the same additive package recycled across different grades and base oil blends also due to cost. TEOST restricts moly use for example, as we've recently discussed, but in the context of your "best available oil", these restrictions and cost cutting aren't in play.
What numerics? Help us out here who may not be as dedicated.An engineer first behavior is curiosity and questioning, that easy to find anything numeric nowadays with a little dedication.
Thank you very informative.
Please link your website, I’m always ready to learn. Thanks.Oups Patman, I have a group of full-time paid chemists Tribologist I am working with in my companies since the late 70's, since more than a decade I have been around I was thinking you did look at our website..., there are very respectable Tribologist here on I respect the required amount.
Unlike a troll.An engineer first behavior is curiosity and questioning,
You are thinking TungstenHow long ago was that? The sample report on their site shows it as one of the report items, and Oil Analyzers (same place AFAIK) has it on their reports too
He will return in another 15 years.I wonder why he went radio silent.
