Originally Posted by 02SE
Originally Posted by PiperOne
Our rule of thumb here is....when you replace tires that have worn out, that axle gets shocks. For some perspective, we don't rotate tires because we generally buy different tires for drive and steer axles so front shocks are in service as long as a set of steer tires lasts (50 to 100k depending on application). If it's a vehicle that eats front tires...chances are the whole front end is working hard so shocks and tires together seems to work. For light duty strut type applications (cars etc) we do rotate tires and will do struts and shocks when all 4 tires come off generally.
On that schedule, on one car I'd be replacing shocks at
A maintenance schedule appropriate to the vehicle and it's use, is what I go with.
You change your tires at less than 2000 miles ? Me thinks you have bigger problems than shocks.
