- Joined
- Nov 29, 2009
- Messages
- 10,258
So on a carburetor you take it off and spray carb cleaner thru all the tiny holes (jets). What do you for fuel injectors?
either take them off and send them to @Trav to have them cleaned or run a fuel system cleaner like BG Product's 44k through them.So on a carburetor you take it off and spray carb cleaner thru all the tiny holes (jets). What do you for fuel injectors?
I run the boat regularly on the trailer, but its like if you dont actually take it out on the lake and run it up in the rpm range is when i have issues with it not wanting to accelerate past like 3000rpm unless I dump it in the lake more often. Runs great on the garden hose, but i dont know If its going to have a problem until out on the lake. Its so odd. Last time i just kept it around 2000rpm for a while in hope that would clean things out, then after doing that for a good 30 minutes it went back up to my usual 3800 rpm cruising rpm. Although it did seem a bit slow for the rpms to come back down which I thought was weird.If it will start and run as is, I would do this first.
"Dump a bottle of Techron in a fresh tank of gas"
Ahhh... a boat, you should have mentioned that.I run the boat regularly on the trailer, but its like if you dont actually take it out on the lake and run it up in the rpm range is when i have issues with it not wanting to accelerate past like 3000rpm unless I dump it in the lake more often. Runs great on the garden hose, but i dont know If its going to have a problem until out on the lake. Its so odd. Last time i just kept it around 2000rpm for a while in hope that would clean things out, then after doing that for a good 30 minutes it went back up to my usual 3800 rpm cruising rpm. Although it did seem a bit slow for the rpms to come back down which I thought was weird.
What motor?I run the boat regularly on the trailer, but its like if you dont actually take it out on the lake and run it up in the rpm range is when i have issues with it not wanting to accelerate past like 3000rpm unless I dump it in the lake more often. Runs great on the garden hose, but i dont know If its going to have a problem until out on the lake. Its so odd. Last time i just kept it around 2000rpm for a while in hope that would clean things out, then after doing that for a good 30 minutes it went back up to my usual 3800 rpm cruising rpm. Although it did seem a bit slow for the rpms to come back down which I thought was weird.
Just a sbc 350 with a multi port injection system installed on it.What motor?
Ok - if possible to temporarily use a six gallon boat tank - fresh fuel and Redline fuel system cleaner … Start doing your periodic starts on that …Just a sbc 350 with a multi port injection system installed on it.
Yeah. I think its called a proform intake manifold. Supposed to give it a little extra bump in hpWould that be the Vortec marine intake or something else?
You don't use the suffix "-banger" to describe a 6 cylinder vehicle. It's a 6 "pot". Four cylinder cars are termed -bangers because historically they're not as smooth as sixes.Once you figure it out let us all know the results. My father inlaws truck has been sitting for 15 years and eventually I'm going to have to tear into it and get it started. It's a 99 dodge ram 6 banger with zero body rust.
118 gallons. Wish I had an easy way to. Maybe just pull the return line off and fill up some 5 gallon cansPrevention, prevention, prevention. Put fuel treatment in every season and never, ever run it on last year's gas. Drain them tanks.
That's a lot! Maybe install a pump and gas up your cars from it during the fall?118 gallons. Wish I had an easy way to. Maybe just pull the return line off and fill up some 5 gallon cans
Are you anywhere near a fire department training center ?118 gallons. Wish I had an easy way to. Maybe just pull the return line off and fill up some 5 gallon cans
I drove the old dodge a few times many years ago and it was a banger. Looks good on the outside but the engine was pretty rough.You don't use the suffix "-banger" to describe a 6 cylinder vehicle. It's a 6 "pot". Four cylinder cars are termed -bangers because historically they're not as smooth as sixes.
