- Joined
- Nov 29, 2009
- Messages
- 9,608
The carbureted gm350 in my boat always seems to idle higher after it's good and hot and nicely warmed up. The difference is about 100rpm and it's kind of annoying honesty. Also if you let it idle for 30 seconds or so it will generally slowly lower back down from say 800rpm to 700 where it should be. Then when you put it in gear it drops to 600rpm. It has an original 715cfm Holley 4 barrel made for Volvo penta. Someone told me it's probably my shift cable that might have some slop in it and that's what caused it. Then the engine vacuum pulls the idle back down on its own. It's frustrating because on a boat you need the engine to idle right so you can dock the boat. Is this just the nature of a carbed engine?
