In their brochure for an automated tire changer, Hunter Engineering implies that 50% of tire sets have at least one tire with less than optimum tire bead seating, and this can lead to vibration issues. The bead can be sealed against air leakage, but not be completely seated.
http://www.hunter.com/tirechanger/revolution/6724-T.pdf
They write on page 14 of the PDF that the "bead massager" feature on the Revolution Tire Changer can significantly improve 50% of tire sets (defined as one or more tires in the set has a 7lb reduction in road force variation). It does this by having two rollers go around the entire circumference of the bead area.
