JHZR2
Staff member
I just don't get it. Maybe I just have a personality flaw, are too disorganized, impatient or something, but I cannot do car work for the life of me. I am pretty handy, and can build all sorts of chemical process equipment, as well do any sort of household project. However, when it comes to working on the car, my skill just plain suck and keep me from enjoying the work, and doing a good job.
Case in point: Today, I wanted to change my fuel injectors. Simple enough, just remove the intake and then pull the fuel rail. Well, for me it isnt so simple. After spending about an hour getting the intake manifold off and then getting the fuel lines off of the fuel rail, I had the worst case of trouble getting the injectors out. I tried to pull them all out at once, still clipped to the fuel rail. Finally got three of four out, the other stayed atached to the intake. I checked everything, replaced the injectors, etc., put them back in,tighetened everything down and put the intake back on. Only to find that I didnt put the injector clips on, so I had to pull everything off. Well, as I was putting one of them on, I dropped it and lost it somewhere in the lower portions of the engine... It was never found. In my second try, I couldnt get the hose that sends coolant to the throttle body to go on in a position so that I could tighten the hose clamp. After I got that, I couldnt get the throttle body straight enough to slide up all the way on the studs that it bolts to.
The story goes on and on, but all in all, it took me from 9am to 5pm to replace 4 injectors. I stopped for about two hours in the middle, but the rest of the time I was out there fiddling. When all was said and done, I had lost one intake nut, one injector clip and one 4.5mm 1/4" drive socket.
And thats the story of most all of my car work. If its anything more than an oil change or maybe a differential change, I cant do it. OK, I guess I can do 4 cyllinder car spark plugs too, but thats really it. brake job all around including rotors took me nearly 2 whole days!!!!
I am really impatient when working on the car, maybe because I have to work in my apartment parking lot. Maybe also because when I need a tool, I have to climb 3 floors of stairs to get it. But I just can't stand doing the work. When things go right, efficiently, quickly and well, I love doing the car work. But, more often than not, a story like today is what reality is, and it isnt fun.
Am I just that bad of a wrench? Is it that Im too unorganized (I leave most tools and small bolts/nuts in the little areas under the hood, which I guess isnt smart). I know I have the ability to do tasks, but other jobs dont seem to take so long with so little getting done.
Do others end up spending nearly an entire day outside working on their car just to end up realizing that almost nothing worthwhile got done, and if you took it to a good garage or dealer, that they would have had the job done in 2 hours without issue?
Sorry, but I had to vent, and have to wonder if others are like me... It seems like everyone who posts on these boards is so mechanically adept with regards to car repair, that almost no job is too big... swap a differential? radiator? etc? easy.
I did change my ABS pump and my alternator, but both took longer than they shuld have (nearly a day for each), with plenty of bruised and cut knuckles and lots of yelling. Do others share similar experiences, or can others give tips on how to get the jobs youre doing to go along well and for things to go right?
OK, done venting... Thanks!
JMH
JMH
