How anal are you about funnels ?
Boston
I usually don't clean them after use and then take a rag to them before using again. Sometimes little dirt gets in on the next run (very little). oh well.
I usually clean thoroughly and then wipe off. That way, no dirt gets on it. Oh, we're talking about funnels and not something else in the thread title...
I clean then store small ones in gallon zip-locks. I clean and cover large ones.
I used to be far more anal about it, now I clean it down with brake cleaner and just bag it. Next time I use it, a quick once over with brake cleaner. I don't like contaminating new fluids with other unrelated fluids or dirt. I will not use any funnel I cannot clean (practically, like the ones with the flexible spout, good luck cleaning that out).
I do the same thing. It's so easy to clean funnels; it makes zero sense that you're OK that a "little dirt gets in"!
I cringe when I watch YouTube videos of people doing fluid changes and it looks like they haven't cleaned the funnel at all. Especially when they're using a coolant funnel and it looks like it's covered in dirty oil.
Mine get wiped out so they don't dribble on the peg in the storage. The peg is a nail in a stud. I don't want oil running down my framing ...
I cut the first bottle in half and use it as a funnel and then throw it away.
Terribly anal. When done, they get carefully wiped out and then washed in dish soap and hot water. When they dry, they go into a large plastic tote bin so they stay clean and dirt free.
I have about ten different funnels and stay on top of them so they are clean and ready when I need them.
Wipe them down and run them through the dishwasher when wife is out.
Now that's anal!
I just wipe before using.
I often store the funnel in a trash can, with some left over towels from the last project, that way gravity will do its thing and get most of the leftover oil off.
Dishwasher then in a Ziploc bag.
Remember the old metal can hole puncher and oil spout?
When finished the attendant would hang it over the garbage can to drain. This is outside.
