Guys, I am hoping you can help me solve this one. 2006 corolla. Horn does not work when I press the steering wheel button. However, the car's alarm beeps when I press the key fob. Beep also stops when I take out the horn fuse.
So I suspect it's either the horn pad button or a horn relay. Where can I find the horn relay? It was not in the same box as the horn fuse. Is it under the dash?
Is there a way to test the horn pad? Is there a switch or button under the airbag that I can short to make sure I am getting current to the horn pad?
Thanks!
Thanks!
