Honda MTF UOA | 7200 mi | 03 Civic
Midwest
On 2/26/23 I had my manual transmission rebuilt (two bad bearings). In November of 2023 I had a UOA done that showed the typical high iron and silicon you see right after a rebuild. See here: https://bobistheoilguy.com/forums/threads/2003-civic-m-t-5763-mi.375976/
So now, a year later, I wanted to check the progress, and it's looking really good. Ignore the viscosity being flagged. That is due to me incorrectly IDing this fluid grade as SAE 75W90. I've since changed it to what it should be (SAE 75) and have asked for them to redo the report to reflect that.
I really need to do a VOA, as I believe Honda reformulated this fluid recently. It would also be nice to see virgin #s of the TAN and oxidation. But I probably won't be doing another UOA for at least 15k based on the numbers below.
Sounds like the rebuild is working good and the report looks good. It shows you added 2 qts on sample #1?
Yeah I saw that too. Must be a mistake. Maybe I filled the wrong field when I submitted that sample.
I recently sent off UOA for my John Deere and put on the slip I used Rotella 5w-40 but it was actually Super Tech 15w-40. 40 yrs is not being kind to me. Glad I'm not alone. 😄
Comparing a UOA against a VOA is good practice.
Use trending, that is, watch what happens to the various metal elements. Snapshots tell us little.
See the first list of lubricants in this list as they apply to these LV MTF fluids:
I did a VOA for this oil in January 2022. It looks very similar to my recent UOAs, but the TAN is over 3, which leads me to believe there was a reformulation since my used TANs are now around 2. Hence, my comment about really needing to redo the VOA.
