2007 Honda Civic - 1.8L 4 cylinder engine
OCI: 7,525 miles over 9.5 months
OLM: 5%
Typical commute is only 6 miles each way, highway trips filled in most of the rest of the mileage. My driving style is very gentle. The car rarely goes above 3k rpm.
I did the UOA mostly to see how well Honda's OLM worked. I estimate it was less than 100 miles from reading 0% when I changed the oil. Results look reasonable to my untrained eye. TBN of 1.4 is acceptable, and wear metals are expected to be high for a new engine.
BLACKSTONE: Don't be alarmed by all the highlighted numbers. We expect to find most anything in the first few samples from a new engine. The excess wear metals are from new parts breaking-in, while silicon is from sand-casted parts and sealers used when assembling your engine. Both should improve with subsequent oil changes. Universal averages are based on an oil run of ~5,200 miles. With a few more oil changes your engine should look that good, if not better. The TBN read 1.4 so you had some, but not much, active additive left. 1.0 is low.
Code:
Oil Honda factory fill
Grade 5W20
Miles on oil: 7,525
Miles on Car: 7,525
Sample Date 06/24/08
Make up oil: 0 qt
Universal
Aluminum: *59* 4
Chromium: 1 1
Iron: *37* 9
Copper: *10* 6
Lead: 0 3
Tin: 1 0
Molybdenum: 370 79
Nickel: 1 0
Manganese: 4 1
Silver: 0 0
Titanium: 0 0
Potassium: 3 2
Boron: 140 57
Silicon: *139* 10
Sodium: 13 13
Calcium: 1845 2257
Magnesium: 12 148
Phosphorus: 697 722
Zinc: 854 852
Barium: 4 0
Should be:
Sus Viscosity at 210F: 51.9 46-59
cSt Viscosity at 100C: 7.84 6.0-10.2
Fashpoint in F: *355* >355
Fuel Percentage: TR
Antifreeze: 0.0 0.0
Water: 0.0
Insolubles: 0.4
TBN: 1.4
OLM: 5%
Code:
Grade 5W20
Miles on oil: 7,525
Miles on Car: 7,525
Make up oil: 0 qt
Universal
Aluminum: *59* 4
Chromium: 1 1
Iron: *37* 9
Copper: *10* 6
Lead: 0 3
Tin: 1 0
Molybdenum: 370 79
Nickel: 1 0
Manganese: 4 1
Silver: 0 0
Titanium: 0 0
Potassium: 3 2
Boron: 140 57
Silicon: *139* 10
Sodium: 13 13
Calcium: 1845 2257
Magnesium: 12 148
Phosphorus: 697 722
Zinc: 854 852
Barium: 4 0
Should be:
Fuel Percentage: TR
Antifreeze: 0.0 0.0
Water: 0.0
Insolubles: 0.4
TBN: 1.4
