I'm looking to buy Two EU2000 Honda Generators however this entire issue of parallel tandem connection is more than puzzling. I once worked as an aircraft A&P mechanic so I have a solid understanding of basic electronics.
My local dealer says it better to use a Companion model along with standard Eu2000 and use the 26 amp outlet?
A dealer in Montana has a special cable to get 30 amps directly off a special made parallel cable with a twist connector using 2 standard EU2000 and he says forget the Companion model? This cable is sold on eBay [search for EU2000***]. It's fuzzy if this set up is properly protected from over loading?
The standard model has a 12 volt output for charging which I like however if I buy a companion model I loose the 12 volt out put? I'd like to have maximum DC output. If they are in parallel does this double the charging amps?
In the future I'd like to use both generators for charging deep cycle batteries if at all possible to use in a light duty back up power situation.
So can anyone here help clear this issue up for me and what combination would be best.
You can answer here or you can PM me your phone number and I'll call you on my nickel just let me know what is the best time to call.
