Honda Element Question
Retired | Wausau, WI
I have a Honda Element and was thinking about changing the rear diff oil. Honda says to use Honda Dual Pump Fluid, "do not use ATF". What the heck is Dual Pump Fluid?
I also assume the front diff runs off of the ATF that goes in the automatic transmission. Is that correct?
Thanks for any help.
Forget about the above post. I should of practiced what I preach and done a search. Found the answers to my question by just doing a search.
Fred: I think the VTM fluid goes in the trans of the hybrid Civic. The Dual Pump Fluid goes in the rear diffs of the Element and CR-V.
Bro: Thanks for your support.
I have been informed that the VTM fluid goes in the diffs of the Honda Pilot. All Honda automatic transmissions take the Honda ATF Z-1. The Dual Pump Fluid goes where I said above.
How do you like your Element?? My wife will get a new 4 door 06' Civic or Element at the end of the year. Is the Element noisy at highway speeds (70-80 MPH)?
