This is on a 2002 Civic EX with 57,000 miles. I tried changing my coolant today draining the radiator and engine block. I've tried every to get the engine bolt to come off but it did not want to move. What I ended up doing was just drain the radiator, put new coolant in, run the car for around for about 10 mintues, drain the radiator again. I did this about 3 times. I wonder if this is good enough. I stuck with OEM Honda Type II fluid. The only difference is the stock coolant was green and the new is dark blue.
