Honda Civic EK3 CVT / 25,000 miles / Honda Z-1
Florida, USA
Hi,
I'm from the Caribbean and back home I have a Japanese model Honda Civic EK3 Ferio Vi Multimatic. To read more about my car see here:
EK3 Honda Civic Ferio Vi
EK3 Honda Civic Ferio Vi Multimatic Transmission
JDM VTEC-D15B Engine
For all you guys with VTEC engines my car is your grandaddy!!
Anyway, it's age shows.
It has a CVT transmission.
Here is an UOA for the transmission oil after 25,000 miles on Honda Z-1. Yes I know I should be using Honda CVT Fluid but in my defense this was reintroduced in 2006 and I change my oil every 2 years or so and I only recently found out about it.
I'll give you 5 seconds to spot what's wrong but then take your time and tell me how to fix it. Ready? Go!
------>ppm
Cr----->1
Pb----->4
Cu----->2
Fe----->417
Sn----->1
Al----->9
Ni----->1
K------>5
Ag----->0
Si------>9
B------>270
Na----->3
Mg----->219
Ca----->264
P------->0
Zn----->361
Mo----->0
Ba------>0
Ti------>0
V------->0
cSt Viscosity 100°C --------->5.98
Oxidation abs/cm----------->0.37
TAN (ASTM D664) mgKOH/g--->1.26
I'm about to flush the fluid and put in Honda CVT transmission fluid but I have 6 oz of Auto-RX in there and I'll drive it for about 2,500 miles before I flush it.
I've already driven 500 miles.
Thanks
Thor.
Nice info about the D15 engine. I still prefer the B series or even better, the K series engines. Nothing like enjoying the newest technology from Honda.
Fe----->417
Hmmm... think the iron is a little high? And doesn't Honda say that reduced wear is why they require ATF-Z1 in their transmissions? Granted, Z1 was used here in a CVT versus one of their automatic transmissions.
Yeah, that Iron looks mighty high to me to. Here is a UOA (w/particle count) from my Honda from last year using Z1 at 18K miles. Different tranny, of course but, then again, one of Honda's most problematic. I took this test PRIOR to installing a Magnefine. I'll be sampling again in the next month to see how it did. Z-1 formulation looks similar enough (considering different labs)
What kind of Honda transmission is that UOA from?
I wish I'd thought to get a UOA done of the factory fill of Z1 that I dumped from our VUE (which has a Honda V6 and 5-speed automatic tranny) at 30K back in April. The magnetic drain plug (shown below) had quite a bit of metal slivers stuck to it. Guess I'll have to wait until the next drain/fill.
I'm going to put a Magnefine on this transmission and change the fluid to Honda CVT Transmission Fluid and change it every 12,000 miles and do a UOA then.
2000 Honda Accord V6, about 70K total miles at that time.
