How can you do that in 15 min. Say a customer comes in with a low system. First we must test the refrigerant with a refrigerant tester.....Mine cost $1500.If it's ok We must suck the remaining refrigerant out and write down how much we got out. The specs for the AC machine are that it must remove 95% of the refrigerant in 30 minutes.Quote:
15 minutes of work tops.
I have already got 30+ min into it.
Now that it's empty I can replace what O-rings I may suspect. On a Car with snapLocks this will be all the O-Rings. This will take atleast another 30 mins.
I also must remove the orfice tube and inspect it. I don't know what condition the system is in w/o pulling it out. Now I know if I need to add oil.
Put the new tube back in, replace the charge ports or schraders.
Now the rules are that I must pull a vacuum on the system to the maximin vacuun I can achieve at my elevation. I won't get 29.99 @ my 3100ft.
After the vacuum is achieved I must turn the vacuum pump off and wait 5 minutes. If the vacuum rises I either have a leak or I have moisture boiling off in the system.
If it's moisture I must vacuum it again and let it sit. A quick 15 min vacuum is not enough! I have not even got all the air out yet. Once I'm satisfied that the moisture is gone I can add refrigerant and oil/dye to the system.
Once it's charged I must go around the entire system with a refrigerant sniffer.....This will take atleast 15 minutes.
If that checks out ok I will run the car, check vent temps etc.
Shut it down and go over it with a black light. If it still seems ok I must put a sticker on the car showing that I added AC die.
This is the procedures that a shop must follow to properly and legally recharge an AC system except for replacing all the O-rings. They are only required to replace the suspect ones I replace all I can access.
Do THAT in 15 minutes! Most people have no concept of what I takes to properly charge a AC system following the guidelines that the federal govt makes a shop follow.........But any body can go into AutoZone and recharge it at home but thats not the proper way to do it.
There are laws that Have not passed yet preventing an unlicensed person from buying R134A, they are coming though.Some states already have them.
