For the past two winters my 98 chevy truck with the 5.7L has had a higher than normal idle even after it warms up. It is like it never drops down from the faster idle that it has when you first start it up cold. During the warmer months this does not happen and the idle is normal.
There is no SES light showing. Does anyone know what could be causing this? I would think if it was an idle control sensor that it would do it all of the time, not just when it is cold out.
What is the correct name for the sensor that controls idle on this truck and are there any other sensors that affect the idle? Anything else that I should look at?. The truck runs fine otherwise. Thanks.
Wayne
Wayne
