Last week the oil temperature of my E220 Bluetec went up to 134 ° C(273°F) during a trip to the mountains. Is that normal? Car mileage : 195k miles The oil was Mobil Super 3000 xe 5w30 changed just before the trip. Outside temperature: 34 ° C (93°F) . Coolant temperature: 92 -97 °C (197-206°F). The max oil temp was reached after about 30 minutes of uphill driving. After 5 minutes of downhill driving with the foot of the throttle the temp quickly went down to 118-120°C(243-248°F) Are those oil temp readings normal? Am I causing permanent damage to the engine? Usually my oil temps are around 99-105°C (210-220°F) with fully warmed up engine driving on the freeway at 70-75MPH. If the car is loaded or I push it harder oil temps may spike for a short time up to 120 ( 248) but only for short periods of time. So I was a bit scared seeing an oil temp of 273°F. Should switch to a 40w oil? My oci is max 5k miles and I use the car mostly on the freeway cruising at 70MPH Thank you for your responses |
