High Mileage Oil question
Missouri
My car has 154,000 miles ('95 Saturn SC1). I'm the original owner. It has run on synthetic most of its life with a few dino changes mixed in. I have run an Auto-Rx treatment and know the engine is spotless.
This past November, I obtained some Valvoline Maxlife full synthetic (in the O'Reilly 6 for $6 promo).
This was my first time using a high mileage oil. I am now developing some excess oil spotting on my garage floor. Did I make a mistake by using a high mileage oil? Do you think the seal conditioners are causing this?
Otherwise, the oil seems to be performing exceptionally! I could feel a difference in how smoothly the engine ran the day I began using it.
Thanks in advance!
Ryan
High mileage oils use an additive that swell seals.Thats how they stop leaks. Think of a bubble on your seal it thins out the seal material and sonner or later leak starts.
I hightly doubt that a name brand high mileage oil will make your engine leak beyond that leakage from cleaning off a false seal of crud. Then it will recondition the seals. Yes they may use a seal sweller, but it is balanced with other additives so that the whole package conditions the seals, not just swell them to no end.
