In another thread someone reported oil pressure problems with aftermarket filters, here: http://www.bobistheoilguy.com/forums/ubb...ck_#Post2920238
According to the OEM statement, it seems high-percentage filters restrict flow and cause the oil pressure to fluctuate in the engine causing "knocks". In this case low pressure in the hydraulic tensioner caused chain slap.
I had been wondering why Toyota puts OEM filters rated at only 50% filtration in Lexus/Toyota engines while Fram and others market filters with 99% filtration. Now I know why: it seems that too much filtration restricts the flow of oil and in certain engine designs where oil pressure is used to control critical components (like the chain tensioner) this can be very detrimental.
And so for EOMs like Toyota it is wiser to sacrifice filtration for flow.
But honestly I have to admit that I do not know where the oil port operating the belt tensioner is usually located. My guess is that it's after the filter and a restrictive filter causes a high pressure difference between the inlet (where the oil pump pushes the oil) and the outlet, so the oil pressure at the outlet and the oil tensioner could be too low.
Can anyone confirm or correct me regarding whether oil pressure is the one before or after the filter?
