Originally Posted By: i_hate_autofraud
Hi all,
Impact wrenches to get stuff off fast is great, I do it all the time.
Using them to fully tighten wheel nuts on regular cars and SUVs not recommended (GM TechLink Nov 2010) and Torque Sticks don't work, they're a scam.
I have 1 old cordless impact wrench that maxes out at 80 Ft/lb, so I use it as a nut runner when pulling / putting wheels on the cars, then use a good click torque wrench for final torque, (100Ft/lb) after rotten dealer abused the wheel studs, snapping one last time and refused to replace them all !!!
I used a clicker for a while, but then I bought the HF torque wrench calibrator, and just use that on a breaker bar. I orient the readout upward, and can quickly run the lug to 30-60-90-120-150 or whatever pattern I wish, without changing any setting. [If I wanted to, I could change the beep setting from its current 80 ft-lb, but that'd require more work than just reading it.]
