HF HNBR O-Rings: Safe for long-term fuel exposure?
CA
Had to remove the fuel dampener (part of the fuel rail) in order to perform some repairs on an engine. The o-ring on the fuel dampener was damaged during the removal process. My pack of HF HNBR o-rings has the correct size. However, is this material suitable for long-term exposure to gasoline?
I'd say no. Seems I remember wanting to one day and rubbing an HNBR O-ring with my fingers and some carb cleaner and it disintegrated. Go with nitrile rubber.
I am an HF fan generally, but am wary about using their stuff in critical applications like fuel. You are probably safe, but I'd be temped to let one soak in fuel for a bit before I commit, if you have the time.
Critic if you like fire use HNBR o-rings to seal gasoline lines.
HNBR should not for use with gasoline
HNBR is just Nitrile (Bina-N) souped-up so that it can have a higher temp rating.
Viton (Flurocarbon) or souped-up Viton are the only o-rings designed for today's gasoline.
PS: The quality of HF Viton o-rings are so poor I would not use then on a lawn mower.
Originally Posted by bmwpowere36m3
I wouldn't trust HF o-rings based on what I've seen. Poor molding, flash and QA. Can't you get this o-ring from the dealer?
True, I forgot gasoline is not gasoline anymore. My bad.
I believe gasoline applications typically uses Viton rubber. Buna-N or HNBR has stronger strength and good for gas but Viton is excellent for gas. IMHO, I think I would go OEM in this situation just because of my fear for a highly critical sealing and don't want leaks.
You don't have to take my word about HNBR conduct a simple test yourself.
Take two new HNBR o-rings that are the same size.
Find a clean glass container like a baby food jar and put enough gasoline in to cover the o-ring.
Put one o-ring in the jar of gasoline and put the other same size o-ring in a plastic bag and label it.
One week later take the HNBR o-ring out of the gasoline and compare it with the one in the plastic bag.
The untouched HNBR o-ring in the plastic bag will have magically shrunk.
Oh, and the last thing is I don't think any vehicles especially Japanese follow the SAE AS568 standard for fractional sizes with fuel rails which your o-ring container uses. It's probably metric sizing so even though it may appear to fit, the gland, major OD, and well dimensions won't allow a proper squish on the o-ring profile so again, my recommendations is not so much material compatibility but more of dimensional fit up concern.
As I understand it, older rubber fuel hose is nitrile/NBR. Newer ones have a fluoroelastomer liner to deal with alcohol and diesel additives.
Thank you for the information. Since this is a critical application (fuel pipe which connects the damper to the fuel rail), I decided to buy the o-rings from the dealer.
I did have one of the green HNBR O-rings in service for one day without issues, but it did get a bit softer.
