Hey, folks.
Honda Accord (known as Acura TSX in the U.S.) owner here. 2.0 l gasoline engine. Living and driving in Greece. Still hesitate between two Mobil 1 oils.
5w30 ESP OR 0w40.
Here are the specs:
Mobil 1 ESP Formula 5w30 specs:
SAE Grade 5w30
Viscosity, cSt (ASTM D445)
@ 40ºC 72.8
@ 100ºC 12.1
Viscosity Index 164
Sulphated Ash, wt% (ASTM D874) 0.6
HTHS Viscosity, mPa•s @ 150 ºC (ASTM D4683) 3.58
Pour Point, ºC (ASTM D97) -45
Flash Point, ºC (ASTM D92) 254
Density @ 15.6 ºC, g/ml (ASTM D4052) 0.850
MOBIL1 0w40 Specs:
Mobil 1 0W-40 Value
@ 40ºC 75
@ 100ºC 13.5
Viscosity Index 185
MRV at -40ºC, cP (ASTM D4684) 31,000
HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, ºC (ASTM D92) 230
Density @15.6ºC, g/ml (ASTM D4052) 0.85
I guess they are pretty similar and both should work pretty fine, however, in terms of protection/fuel economy/performance what would you choose?
Thanks.
5w30 ESP OR 0w40.
Here are the specs:
SAE Grade 5w30
@ 40ºC 72.8
@ 100ºC 12.1
Viscosity Index 164
MOBIL1 0w40 Specs:
Mobil 1 0W-40 Value
@ 40ºC 75
@ 100ºC 13.5
Viscosity Index 185
Thanks.
