I recently purchased a 1992 Olds Cutlass Ciera 3.3 6 cylinder with only 79K miles. I want to drain and flush the radiator but am not sure what to refill with. I've read thru many posts on this forum (Dexcool, Deathcool, etc.) I am not sure whats in it now, but its brown and probably hasn't ever been changed. The owners manual does not specify it must be Dexcool but the local auto parts place says it probably is. I plan on a drain and refill cycle of 2 - 3 years, but don't want to ruin the engine just by using the wrong coolant.
Bonus question - what type of vehicles need/use redline's water wetter? I guess I'm not clear on the benefit if you keep your coolant clean and at the proper mixture.
Any help would be appreciated!
