Sierra048
Originally Posted by 4WD
Originally Posted by tblt44
My 2 4l60e, I added drain plugs.
The auto parts store has them under 5 bucks.
Drill a hole and install the drain plug.
You MUST make sure nothing is behind the area you plan on putting the plug.
The nut and washer on the inside of the pan are probably 1/2 thick.
I will try to get pics later today
Used these several times … recommend replacing the nylon washer with copper washer.
First change I will suck some fluid from the dipstick tube, pull pan to clean magnets, add plug, and change filter.
After the first change I do drain & fill based on miles or time …
I plan on following the same schedule once I drop the pan and get the filter replaced. I ordered a steel bung with a plug and washer specifically designed for transmissions. Already talked to a welder who said he would charge me $20 to weld it on. So now, my only concern is getting the pan off, and back on again. Anybody else who has tackled this job please chime in and let me know what you did to overcome the exhaust pipe obstacle.
