I've been doing quite a bit of reading on brake pads over the course of the last couple of days, and to be frank, it's really done my head in. I'm trying to find the best pads (for the Mercury) for my driving conditions.
I've been running Motorcrafts, and my biggest complaints are grooved rotors and brake noise. There's also an issue with brake dust, but that's not as much of a concern as the previous issues. Even though I always bedded them in after installation, I'm not at all satisfied with their stopping power either.
The biggest issue with my driving conditions is congestion on the freeway. You'd be doing 75+ MPH and will be required to slow down to a complete stop at one point or another. There's either a bunch of geniuses forming two or three lanes to take an exit, causing the congestion, or an accident.
I have to be extremely careful when slowing down, because sometimes (more often than I like) my front brakes literally lock up (no ABS). I don't jam the brake pedal all the way down either, I just brake as I normally would (smoothly at first then slowly and gradually increasing pressure without jamming the pedal). But the fronts randomly and unexpectedly lock up.
I've looked into the Ford OE brake pads, which cost at least double the Motorcrafts with the cheapest deal, but then I decided I would look into ceramics.
I first looked into EBC Red Stuff pads, but got put off after reading posts on Crown Vic forums about warped rotors and such with these pads. I then looked at Raybestos Police pads (semi-metallic) until I started researching the different materials (semi metallic and ceramic). Then I had a look at the Hawk HPS pads, followed by the Performance Ceramics. Then doing another search, I've seen people speaking highly of the Bendix CT-3 pads.
Now I'm completely confused with what to go for. The basic "requirements", if you like, are as follows:
- Ability to come to a stop from highway speeds without locking up unexpectedly
- Handle heat well
- Give the pedal a firmer feel
- Will not squeak under light braking
- Will not groove the rotors
- Give out the least brake dust
Also worth noting, I brake smoothly and am not hard on the brakes. But in the event of an emergency stop, I need something that will stop the car and not lock the wheels when I'm not jamming the brakes.
As far as changing the brakes go, I generally take the rotors off and generously spray them with chlorinated brake cleaner to remove traces of the previous pads as much as possible. Depending on condition, I may get them resurfaced. I replace my brake fluid whenever I do a brake job or every year, using DOT 4. I use Motorcraft Dialectic Grease on the caliper pins and on the backs of the pads. My brake in procedure is also as follows:
- 6 x smooth stops from 35 MPH - 0 MPH
- 4 x smooth stops from 45 MPH - 0 MPH
- 2 x smooth stops from 65 MPH - 0 MPH
- Allow the car to sit for at least 2 hours
I would muchly appreciate input on which pads would be most appropriate for these requirements. Thanks!
- Handle heat well
