Hi all,
The car is a 93 Pontiac Trans Am, 7.5" 10 bolt rear, 3.42 gears, Auburn posi. The manual calls for 80w90 GL5 with a bottle of GM Limited Slip additive.
Normally I've been running Valvoline 80w90 with the GM additive. However I've been having constant problems with leaking from the pinion seal and gear whine. Now I sure the gears are not setup properly which would explain the whine but I've replaced the pinion seal 3 times in the 2 years o've owned it and the repairs never last more than a few weeks before the leaking starts again. The mileage (160,000 and counting) probably isnt helping either.
This weekend I'll be picking up an entire new rear end (im sick of messing with this one) and I plan on changing the oil in it before it goes on the car. Any suggestions on what brand/weight oil to run that might help with the problems I've been having? Perhaps a heavier oil (say 75w140) would help? Otherwise I'll just stick with the 80W90 and the additive and hope for the best.
Thanks!
BTW in case you think I'm crazy its actually cheaper for me to buy a used rear end ($200) than it would be to buy a rebuild kit and pay someone to redo the current one. Not to mention it will have less than 1/2 as many miles.
Thanks!
