!-HELP-! Oil Capacity for 2004 Toyota Echo
You do need to find the other piece, but I bet it is in the tube. Removing most Toyota oil pans is not a trivial task. Even if the access is unrestricted (which generally it is), the Toyota FPG used to attach the pan is like welding it on the block. Toyota has a special tool to cut the seal, without cutting it there is no way you will get that pan off if FPG is used to attach it. The upside is that they almost never leak but getting it off is not easy.
Originally Posted By: yvon_la
Sadly you ll need to find the missing part of the dipstick .so rénovationthe oil pan and search if its the engine end ,if its the other end ?waz likly stolen ,go buy another.you dont want to overfill or underfill.and yes you have to warn garage to not overfill .most of the time they dont look on the diptick after the car ran. Till oil filter is filled (and car has cooled 30 minute
