Morning all, had some codes pop up this morning, a few of them I'm pretty fluent with (owned Fords long enough) but a few are newer. 2003 Mustang GT, 4.6L. One code P0358, ignition coil malfunction, which is common among any 4.6 I've come across. Easy to change, no issue there. I also, however, got codes P0207 and P0208, Injector Circuit open on cylinders 6 and 7. Could this be thrown off by the ignition coils, or do I most likely need to do an injector job? Car is bone stock with 125K, so I didn't expect it to need injectors, but if so I can make it work. Should I try running Seafoam through to see if their just dirty/clogged? Thats what the AutoZone "mechanic" suggested, normally I don't give what they say a 2nd thought, just trying to save a little cash
thanks all! (Also, came up with a B1318 code, battery voltage low. I know that when the misfire started, the RPM's did drop and rise quite a bit, could it just be that the RPM's dropped too low to charge the battery temporary?)
