Hi fellas! My son bought 97 s10 high mileage fairly nice truck.run great,good oil psi,no smoke.after a week he did oil change and it started knocking.called me i lostened to it,pulled plug wires one at time no difference.so im thinkink piston pin?overnite read alot about balance shaft problems so tore front off and chain wore out.i oreder aftermmarket tensoner timing chain kit.pulled engine enough to take oil pan off oil was sludge,only from one day!no movement in rods,couldnt move pistons.put in hv oil pump thinking no oil flow or something.get engine together and starts knocking after warm and when rev engine the knock is like double speed(rattle).he spent all his money and wants to drive until we can get a good engine.any ideas of the knock on 4.3 or a additive to put in oil to prolong quiet down?seen u tube vid,a guy put rislone and stp oil treatment in and a week later piston noise was quiet.any thoights?
