From here: https://cdn.shopify.com/s/files/1/2...TION_INSTRUCTIONS_09-13-2023.pdf?v=1694606490
I can see that they want the gaps offset by 90 degrees, but I can't tell what the piston orientation is?? I'm guessing the round shapes on the piston surface are supposed to be a hint, but I'm not sure. Is the bottom of the diagram the exhaust side of the psiton? So the horizontal line is the pin axis?
In general, there seems to be so much different advice in terms of how to orient the 2 top rings as well as the 2 rail rings which make up the oil seal. Some say to put the 1st ring gap facing the exhaust, while others like the Wossner documentation seems to want everything offset by 45 deg. What gives??
For context this is going into an XR650L Honda dual sport.
