My wife's '95 Civic is displaying some low-grade issues that I can't quite say are related, but can't quite pass off as coincidence, and that aren't really that bad, but bug me enough to want to check it out.
Before I begin, FYI there is no MIL lit, and no codes in memory. It is a '95 SOHC with about 120,000 miles.
First of all, the car displayed some hard-starting issues a couple of months ago -- only after the car had sat for quite a while -- accompanied by a slip in mileage -- nothing drastic, but noticeable -- from 36 MPG to 33 MPG. I replaced a vacuum hose on the fuel pressure regulator, and the hard-starting issue was solved, but the mileage remained where it is.
Next, we noticed that the temperature gauge was creeping up higher than usual when the car was idled a lot. The fan kicks in and cools it down with no problem, just a lot later than it used to. It never gets near the red, but it was enough for even my wife to notice. In other words, it's doing what it's supposed to do, but it's not behaving the way it used to. When the car is driven, it's fine.
Finally, while I was idling the car to see if the fan would kick on, I noticed that every two minutes or so the idle would kick up a few RPM, stay there for 10 seconds or so, and then go back down. It isn't "erratic" -- it occurs in regular cycles. Since I haven't made a habit of idling the car and listening to it for long periods of time, I don't know if this is normal or not.
All that to say, I'm thinking that the thermostat is starting to go. I say "starting" because it isn't exhibiting any of the symptoms of all-out failure, open or closed. Am I crazy? I'm thinking the thermostat is starting to go, and the ECM is compensating by running in open loop, or some such thing, hence the mileage drop.
Any thoughts would be appreciated.
[ July 23, 2003, 06:17 PM: Message edited by: kev99sl ]
