Pull it apart like the other guy did and make sure you pull that oval shaped white plastic thing out of the bottom of the carb and spray that with carb cleaner, use the carb cleaner to really blast out the passages in the white oval and up inside where the white oval goes with the carb cleaner.
Mine was running bad so I gave it one glug of techron fuel system cleaner and that stoped it dead. It softened the varnished gas and turned it into gasoline bugers which plugged up the carb. Disassembly and a good blasting of carb cleaner got it going good as new.
