I'm having a very nice long discussion on the benefit of GL-4 over GL-5 oil. So far through searching on this site I've already learned a LOT.
Anyway the topic of our discussion is basically about the safety of GL-4 versus GL-5 and it's sulfur content and how it affects 'yellow' metals, specifically in Mazda MX6's.
You can view the discussion here: MX6.com...Changing My Tranny Fluid? The real good stuff starts about 1/4 to 1/3 the way down between Ryan (me) and SleepCounter
I've already searched read through the following threads and sites:
Reactive vs. non Reactive sulfur
GL-4 VS. GL-5
http://www.lube-tips.com/BackIssues/2002-04-03.htm
http://sbcc.ca/tech/lube1.htm
So I've got a lot of great info to prove to him my point...but I need some more info that I couldn't find.
Helpful things would be actual sulfur concentrations in various GL-4 versu GL-5 oils (Especially Redline) and wether they are of the active or Inactive type. Another is the longevity and shifting performance of using a GL-4 or even a safe GL-5 oil over traditional ATF (which is what Mazda transmissions come with).
Also something I had no real hard info on, what kind of temperatures are produced by changing gears, or more specifically those esperienced at the synchro and gearface and wether it would be enough to cause 'active' sulfur to cause damage, keeping in mind we're talking about performance sports compacts that see drag strip duty.
Thank you in advance.
Laters
Ryan
GL-4 VS. GL-5
Laters
Ryan
