On street cars with oil temp gauges, I've always seen higher temps with heavier oil [all things equal]- it must not transmit the heat as well, and has higher internal friction.
The journal bearing design equations are based on decades of emperical data. There is no need to play the blind man and elephant to figure out what is going on.quote:
Originally posted by Gary Allan:
I don't think you can settle this "chicken or the egg" debate outside of a test bench dyno engine. Too many uncontrolled variables.
Oil pressure above 4000 RPMs was essentially the same xW30, xW40, and xW50 at 95 PSI to 100 PSI (hot). The xW50 oil was up 3-5 PSI in this rev range compared to the thinner oils (Track hot).quote:
Originally posted by 1sttruck:
On the track results with 30, 40 and 50 weight oils - what was the oil pressure at similar temps ? Was the oil pressure lower with the 50 weight because it was hotter, or because of some other reason ?
The car may have seemed a bit happier with the thinner oil. And by this I mean the note from the engine not in any sense of power delivery.quote:
Did the car run differently with different oils ? Did other engine temp indicators such as coolant correlate with the oil temp ?
I don't understand the mechanisms involved, only the data points.quote:
I was wondering if as someone else noted, was the car running hotter or did the thicker oil not release heat as well.
Okay, I'll accept this as fact ..just because I know you don't talk crapquote:
Could it be that the thicker, denser oil has the ability to contain more thermal energy and thus actually cools the engine parts more effectively?quote:
If an oil is very thick, more energy is required to run the oil pumping process than when the oil is thinner. Here the movement of oil through the engine is adding heat to the oil.quote:
For the sake of real world discussion here ..let's say I run a 20w-50 vs a 5w-20 in near identical conditions and they both result in near identical oil sump temps at highway speeds. What's my take on it since my only apparent difference is oil pressure?? What compensatory mechanisms are at work here to make this possible when all other things appear equal? [/QB]
Just curious, which 5w30 did you use that has this high of an HT/HS? RL?quote:
Originally posted by Mitch Alsup:
Then as a further experiment, I tried a 5W30 oil that has an HTHS of 3.8.
Mitch Alsup
Yes.quote:
Mitch Alsup
I'm not disputing your assertions here ..but it does kinda remind me of that (either) Greek or Roman paradox between the Lawyer that taught another law on the condition of being paid upon the winning of his first case (I forget the principles names). The student delayed going into practice and was sued for the fees. His position was that if he won the suit, then by court decree, he didn't owe the fees. If on the otherhand he lost in court, then he didn't win his first case, and therefore didn't owe the fees due to their agreement. The Plaintif had a reciprocol arguement.quote:
If an oil is very thin, then internal friction (sliding, scraping, and wiping) add heat to the oil (and wear to the engine). Here, the heat is generated at the point of lubrication to the oil.
So there should be a happy point in between where measured temperatures are lowest. The spread between xW50 and xW20 is great enough that either a xW30 or xW40 might result in lower temps than either of the more extreme oils.
Yes. Rad delta T would be an indicator ..but only if you could index it for flow (both internally and cfm across it, also indexed for temp). That's why I think anything outside of a lab you would have a hard time isolating what elements were passive/sympathetic indications or of more direct/primary type.quote:
It still seems that we need a measure of engine temperature in order to determine if it's actually running cooler.
Absolutely!! This isn't science! This is philosophy.quote:
oooh, real data instead of endless supposition? how much fun is that?
